2001 Magnum reverse problems.
Old Oct 11, 2010 | 04:50 PM
Drewpul's Avatar
Exclamation 2001 Magnum reverse problems.
We have a 2001 Polaris Magnum 325cc 4x4. When the engine is cold, we can't put it into reverse without it stalling. When it is warm, it works fine.
Any suggestions??
Thanks
-Drew
Old Oct 11, 2010 | 05:38 PM
Overdrive's Avatar
I don't remember if the 2001 had a seperate reverse limiter box. If it does all you have to do is unhook the black wire from the box.
Old Oct 13, 2010 | 07:04 AM
Drewpul's Avatar
What dies the limiter box do?
Old Oct 14, 2010 | 03:10 PM
Drewpul's Avatar
If, I disconnect this wire, will it deactivate the override switch as well?
Old Oct 14, 2010 | 04:27 PM
Overdrive's Avatar
If you unhook this wire you will have full power in reverse at all times. Also your throttle safety switch will no longer work. That is fine with me but others may not like that.
Old Oct 14, 2010 | 07:15 PM
Drewpul's Avatar
Thanks Overdrive. Do you think this would fix the problem? The engine dies whenever I shift it from Drive to Reverse.
Old Oct 14, 2010 | 08:34 PM
Overdrive's Avatar
Yes.
Old Oct 15, 2010 | 02:25 PM
Drewpul's Avatar
Where is the override box located at?
Old Oct 15, 2010 | 07:18 PM
Overdrive's Avatar
Under the plastic under the front rack.
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
poutlaw525
Sep 9, 2015 03:19 AM
chewy78
Sep 8, 2015 10:37 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
