AWD light flashing, but AWD works
Old Oct 11, 2010 | 05:50 PM
650bomber06's Avatar
Default AWD light flashing, but AWD works
a while back my dads 05 sportsman 500 speedo quit working, just the part that tells you how fast you are going. he said at the same time he noticed the AWD light started flashing. the AWD works like it should but the light flashes. assuming the hall sensor is bad for the speedo since the AWD is working, why would the AWD light be flashing?
Old Oct 11, 2010 | 06:49 PM
TLC's Avatar
TLC
Just change the Hall Sensor to get the speedo back and see if it also corrects the flashing.
Old Oct 11, 2010 | 07:48 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
On my 2006 Sp 450 I can go into the speedo and check some stuff, Example volts AWD on /off reset the hour countdown for The Wrench icon, (service reminder) ohms reading for the different gears,Miles /Kilometers If you have this on your 05 you can at least see on the screen if the AWD turns on and off properly in this mode first........Caper........
Old Oct 11, 2010 | 08:03 PM
checked that. when switched on, it would flash on-off-on-off. when switched to off, the word OFF would flash. we put the quad up on jacks and tried the AWD. it seemed to be working as it should. engaged when switched on and never kicked in and out of AWD when engaged. , switch to off, hit reverse and let the tires spin , then forward and it would disengage. but the light flahes in both 2wd and awd
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
