Sportsman 500 light part # question
Old Oct 12, 2010 | 07:21 PM
randyneff6971's Avatar
Default Sportsman 500 light part # question
I have a 99 sportsman 500 and I ordered the 2 light bulbs in the front rack, the dealer got 2 lights that my harness don`t plug into the light part numbers are 4030061 they are double filament (<- however spelled) bulbs and there are 3 pins on the connection. My quad the front lights are low beam only and have 2 pins on the connection could the part number for the lights i need be 4030059 ? if not does anyone know the part number i need to tell my dealer so I can get the front lights working again. Thanks allot for the help.
Old Oct 12, 2010 | 08:38 PM
Shows to be 4030061 bulb for all 500's IF its a 99 model?? OPT
Old Oct 12, 2010 | 09:01 PM
Yes thats what the dealer gave me but its wrong wont plug into my harness mine is a 2 wire low beam only, could it be possible my quad was made in the later part of the lineup year and they switched the wiring to the model year newer meaning the bulb # would be also for the newer year (4030059)
Thanks got your help and input.
Old Oct 13, 2010 | 07:38 AM
YEP,very possible mid year change. Microfiche not always correct.. OPT
Old Oct 13, 2010 | 05:35 PM
Thanks thats what I thought called the dealer today and the correct bulbs are on there way. Wish there was a way to tell when exactly the machine was made rather than trial and error on the dealers expense ( ordering, restocking, ordering again) just don`t seam right.
Old Oct 13, 2010 | 05:48 PM
TLC's Avatar
TLC
Bumper Mounted Light Bulb (Polaris part # 4030059)
At this point in time you have no choice but to order the OEM Polaris bulb @ $15ea as there are no aftermarket bulbs available. I have found you can purchase a complete set of driving/fog lights for $20, which will improve the lighting substantially since they come with 55-watt, H3 halogen bulbs and much better replaceable lenses vs. the Polaris 37watt bulbs and non replaceable lenses. Replacement H3 bulbs can be had for just a few dollars.
Other common Auto replacement parts for Polaris. Make a list of common numbers we need
Old Oct 13, 2010 | 07:44 PM
Book marked great info.
Old Oct 13, 2010 | 07:55 PM
HighVelocity's Avatar
According to the Polaris part #, my '03 500SP also uses the 4030059 single-filament bulb, but I have been using GE bulbs, part #886 for a few years now with no issues. I believe they are a 50W bulb. These are available at most auto parts stores.
Old Oct 13, 2010 | 08:14 PM
I took my bulb into an auto parts store and looked at everything and couldn`t find a fit-ment match and there was about 50 different lights to look at. Doesn`t the 886 bulb have a 3 prong plastic lock? where as the polaris 4030059 and the 4030061 is a 4 and the sealing washer on the wrong side of the lock.
Old Oct 13, 2010 | 08:28 PM
You got me second-guessing myself, so I went and checked my machine. Now I feel like an idiot. The GE 886 bulb is used in my high beam. OOPS !! My apologies.
