Sportsman 500 light part # question
I have a 99 sportsman 500 and I ordered the 2 light bulbs in the front rack, the dealer got 2 lights that my harness don`t plug into the light part numbers are 4030061 they are double filament (<- however spelled) bulbs and there are 3 pins on the connection. My quad the front lights are low beam only and have 2 pins on the connection could the part number for the lights i need be 4030059 ? if not does anyone know the part number i need to tell my dealer so I can get the front lights working again. Thanks allot for the help.
Yes thats what the dealer gave me but its wrong wont plug into my harness mine is a 2 wire low beam only, could it be possible my quad was made in the later part of the lineup year and they switched the wiring to the model year newer meaning the bulb # would be also for the newer year (4030059)
Thanks got your help and input.
Bumper Mounted Light Bulb (Polaris part # 4030059)
At this point in time you have no choice but to order the OEM Polaris bulb @ $15ea as there are no aftermarket bulbs available. I have found you can purchase a complete set of driving/fog lights for $20, which will improve the lighting substantially since they come with 55-watt, H3 halogen bulbs and much better replaceable lenses vs. the Polaris 37watt bulbs and non replaceable lenses. Replacement H3 bulbs can be had for just a few dollars.
I took my bulb into an auto parts store and looked at everything and couldn`t find a fit-ment match and there was about 50 different lights to look at. Doesn`t the 886 bulb have a 3 prong plastic lock? where as the polaris 4030059 and the 4030061 is a 4 and the sealing washer on the wrong side of the lock.
