Carb help
Old Oct 13, 2010 | 06:06 PM
zzoomz's Avatar
Default Carb help
Hi, I need help getting my carb off. I hav an '04 600 and the only thing I can't get off is the throttle cable. How does it diconnect from the carb? I took off the black plate and unscrewed the cable at the carb but the I can't get the cable off the carb! Any help would be great. Thanks
Old Oct 14, 2010 | 05:37 AM
zzoomz's Avatar
Has anyone taken their carb off?
Old Oct 14, 2010 | 06:34 AM
sammydogs64's Avatar
On my 02 700, which is basically the same as yours, I changed the jets and raised the needle without taking the carb off. I just unbolted the gas tank and rear gas tank support, loosened the carb clamps and rotated the carb 90 degrees one way to get at the needle (top) then back upright and 90 degrees the other way to get the bowl off and change the jet.
Worked for me. (BTW, you need a long , good quality screwdriver to get the bowl screws off, they strip easy)
Old Oct 14, 2010 | 07:50 AM
Speeddrive1's Avatar
there is a slot in the plate that the cable has to slide thru. You have to hold the throttle plate open with your fingers in order to get slack in the cable to slide thru that slot.
Old Oct 14, 2010 | 04:54 PM
zzoomz's Avatar
ok thanks, I'll try and hold the plate open and slide the cable off. If that doesn;t work I'll do what sammy said.
Old Oct 15, 2010 | 09:11 PM
Kerbbirds's Avatar
If you remove the air box you can bring the carb back in to that hole and work on the top or bottom, may have to cut a couple tie wraps so your cables have enough slack
Old Oct 16, 2010 | 07:12 AM
zzoomz's Avatar
I think thats what I'll do I can get to the carb real easy and there is alot of room to work in that area.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
