2003 700 Sportsman Alternator not charging
Old Oct 14, 2010 | 02:50 PM
mykidsdaddy's Avatar
Default 2003 700 Sportsman Alternator not charging
Can someone tell me if there is a fuse inline or..for that matter...are there ANY fuse on my quad??? I haven't seen a fuse block but that doesn't mean there isn't one there (somewhere) LOL!!!
I finally got to ride my quad for the first time 2 nights ago. Axle issue resolved thanks to American CV Store. I have a 2003 NOT a 2002~~~
Anyway...when I took it for a test ride everything was OK but the battery icon started flashing. I put the battery on a charger overnight and took it out yesterday and it started doing the same thing.
I brought it home, put a DVM across the battery and I had 12.01V.
Revved the motor...12.01V, shut off the motor...12.01V. Alternator isn't gettin' to the battery!
Oh...I don't have a service book YET!!!
Thanks
Old Oct 14, 2010 | 02:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there isn't any fuse for the recifier(regulator), but you might check to see if it's plugged in or corroded connection. the charging system is in the stator(no alternator). you should be pushing a good 13.5 volts when reving the bike on a fully charged battery.
Old Oct 14, 2010 | 05:49 PM
sammydogs64's Avatar
My regulator/rectifier went on my 02 700, battery would not charge but it would still run with a dead battery. I bought a rectifier on ebay for $26, works fine now.
Old Oct 14, 2010 | 05:50 PM
BTW, the rectifier was bolted to the top of the radiator, its a little tough to get at with the front bumber still installed.
Old Oct 14, 2010 | 10:42 PM
No more calls folks..we have a winner!!!
Thank you very much!!! And Thanks to SammyDogs too! I would not have looked there for the rectifier! The red wire was unplugged! I'm not sure if it's an issue, but I was getting around 14.5VDC with the engine revving at a very high idle.
Old Oct 15, 2010 | 02:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
your welcome. w/ the a low battery charge it would be fine to be that many volts. over 15 volts constant i would be worried but i'm sure yours is fine.
Old Mar 31, 2011 | 06:26 PM
refg3880's Avatar
my red wire coming from the reg is unpluged also, but there is noplace to plug it in!?!?!?!?!?! there is a double red unpluged near the reg im asuming this is where it goes but that connectors dont line up im i missing a part?
Old Mar 31, 2011 | 09:07 PM
Depending on build date,the 04 changed from the Ducati system to the reliable Kokusan complete system which included flywheel,stator cdi,coil, and new type reg/rectifier with necessary jumper kits for the regulator. Red wire on regulator has a funky split red connector that does plug into the matching connector. Not sure what you have,but if you have a coil pack instead of a separate cdi and coil and says DUCATI, system needs to be replaced or will cause problems. OPT
slowgsxr97
Mar 18, 2022 03:40 AM
velcro7279
Aug 24, 2015 01:15 PM
sweaver
11
Aug 18, 2015 03:47 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
