2000 325 Magnum 2X4 Idle problems
Old Oct 15, 2010 | 04:42 PM
smtank's Avatar
Red face 2000 325 Magnum 2X4 Idle problems
I have a 2000 325 Magnum Polaris that will not idle without the choke being engaged. Once I get the RPMs up with the choke engaged I can disengage the ATV and run as fast as I want but once I slow down it will die unless I reengage the choke. All new fuel and it has only sat idle for a motnh or so and this problem came out of no where.
Old Oct 15, 2010 | 07:17 PM
Overdrive's Avatar
Check the intake boot. If there is no leak there clean carb.
Old Oct 16, 2010 | 03:52 AM
4getful2's Avatar
still could try cleaning the pilot jet
Old Oct 16, 2010 | 09:35 PM
cwlongshot's Avatar
Thanks for the tip. My wifes 00' 325 TB is doing the same thing!!
CW
Old Oct 17, 2010 | 09:41 AM
TLC's Avatar
TLC
Maybe this is your problem Polaris ATV Thumb Throttle Maintenance Tips: Polaris ATV Maintenance & Repair Tips | eHow.com
Old Oct 17, 2010 | 07:23 PM
cwlongshot's Avatar
Wink
WOW, you learn something everyday!!! Thanks for the tip!!!
CW
toonces
Oct 16, 2019 12:11 PM
wbfjim
Jun 8, 2015 06:20 PM
magnum1
Jun 1, 2015 02:14 PM
MXZ
Jun 4, 2000 11:09 PM
eagles
May 21, 2000 10:37 PM
