shimmy
Old Oct 15, 2010 | 05:47 PM
beagleboy's Avatar
Default shimmy
have a 03 600 twin sportsman, the bike pulls hard to the left and when you take your hands off the steering wheel it shimmys real bad. I have orginal tires and rims. do i need new tires and rims? tahnks
Old Oct 15, 2010 | 07:14 PM
Overdrive's Avatar
You have one rear tire taller than the other.
Old Oct 15, 2010 | 08:58 PM
Kerbbirds's Avatar
check the air pressure in tires and check the alignment.
Old Oct 15, 2010 | 10:40 PM
beagleboy's Avatar
i dont understand what you mean, both tires are the same.
Old Oct 16, 2010 | 06:30 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Ditto, Also check for loose/worn tie rod ends.
Old Oct 16, 2010 | 07:09 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you sure that side hub is not engaging the into the awd? you can check for even tire pressure in both tires to make them the same and if thereres no worn parts as mentioned them maybe the tires them selfs might be out of wack. imo
rockout
Feb 8, 2009 07:27 PM
ZR1BANDIT
Apr 16, 2005 10:19 PM
Just4Kicks
Dec 7, 2004 08:20 PM
scrambler420
Aug 23, 2003 07:14 PM
