shimmy in front end..
Old Aug 22, 2003 | 10:50 PM
scrambler420's Avatar
Default shimmy in front end..
hey guys i just bought some puresports bandit front tires and now there is a very bad shimmy in the front end,all the bushings are new except for the upper stearing post bushing(which is sloppy) and the tie-rod ends are new also..one of my front tires is pointing inward a little bit,
would that cause a shimmy?with my bald stock front tires i didnt feel a shimmy at all so whats the deal?please help..thanks
Old Aug 22, 2003 | 11:00 PM
RookWV's Avatar
Check your toe-in (see maint manual)...could be tires out of balance or even a bit loose......
Old Aug 22, 2003 | 11:05 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you get a bad tire. just a car, sometimes you get a defected tire. you toe in being out would make it handle funny or where tires, but i don't think it would start shimming bad.
Old Aug 23, 2003 | 08:38 AM
dodgepower's Avatar
Check the air pressures too brother is dont match can make it shimmy it has made mine before
Old Aug 23, 2003 | 07:14 PM
the toe-in is pretty close to perfect,im not sure if the tire is a defect or not.i bought new tires and wheels all the way around.im not to sure if they got balanced or not,i dont see any weights on the rim..my tire pressure was high but i lowered them,they have equal amount of pressure..im starting to think that its all caused by the upper stearing post buushing,but im not sure..i also droped from a 23" tire to a 22" on the front i wouldnt think that would matter?
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
