HPD pipe for trailblazer
Old Mar 6, 2001 | 10:51 PM
trailblazer00's Avatar
What are the power gains with this pipe? What does the MTD silencer sound like? Does the machine run a He!! of a lot better?
Thaks to all that replie!!!
Old Mar 6, 2001 | 11:06 PM
waynaferd's Avatar
I had an HPD pipe, but never used it, and sent it back and got a cheaper, prettier, DG pipe. All pipes probably give 6-8 hp, some meor, some less, and the only thing you'll probably hate is at full throttle people will think your harvesting the forest because the damn thing will sound like a chainsaw. I noticed w/ just a pipe and uni filter(before I got the hpd clutch kit installed) my Tblazer would wheelie up alot easier, bog less, and have a stronger seat-of-the-pants pull to it. Get the pipe, than definitely get a clutch kit. The springs and weights change makes a BIG difference, especially w/ a pipe.
Old Mar 7, 2001 | 09:45 AM
TheQuadfather's Avatar
My neighbor put the HPD pipe, MTD muffler and clutch kit on his T'Blazer. It made quite a difference. The MTD muffler is quieter than the standard one. It is well worth the money.
Old Mar 7, 2001 | 10:06 AM
OneDollar's Avatar
I just installed mine ( see thread HPD clutch kit )
I put on the MTD nickle muffler and will test it out today (was too late last night when I finished)
Old Mar 7, 2001 | 04:09 PM
Cobra131's Avatar
I got an HPD Pipe and Clutch kit and wanted it to look nice so i got the nickel plated pipe. It looks really nice and has not had a spec of rust on it yet. Power gains are great. Would definetly recommend it to anyone.
Cobra
2000 Traiblazer
1996 Honda Fourtrax
Old Mar 8, 2001 | 08:38 AM
OneDollar's Avatar
Well took the TBlazer for a short ride down the street (can't wait till the weekend when I can get it in some dirt)
What a difference! The sound of the MTD muffler is sweet. It really sounds like a 2-stroke now. It's not too loud (even though they don't regulate silencers where I ride).
The pull and top speed is quicker. I did notice that off idle it takes slightly more RPM before the clutch engages (is this normal? , it would seem so after seeing the new springs) but once it grabs it feels a whole lot better than stock.
I'm very happy with the look, fit and performance of HPD's products.
Old Mar 8, 2001 | 09:43 AM
OneDollar:
It will engage higher now. You also might find out than it will not go in reverse unless you hold in the reverse limiter too.
Old Mar 8, 2001 | 10:23 AM
OneDollar's Avatar
Yea, I did notice that about reverse. I always use the button anyway. Well I guess I got it put back together right then . Might want to bypass the yellow button now as described by some other member in past threads.
Old Mar 8, 2001 | 01:11 PM
scramblerjer's Avatar
do you know if the power gains are the same with the mtd silencer as without?
Old Mar 8, 2001 | 01:43 PM
OneDollar's Avatar
I don't know about that. I don't think I would want to run it with just a straight pipe anyway, would be way too loud.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
chewy78
Sep 8, 2015 10:37 AM
