400 Xplorer Starting problem
Old Oct 19, 2010 | 01:28 AM
kayden101's Avatar
Default 400 Xplorer Starting problem
Hey
ok i got a small problem with my xplorer 400 1998
it has been doing this ever since i bought it last year and now it starting to get annoying. or little worst. so might as well find out what the problem is now.
problem is after the atv has been sitting for more then a few hours, it wont start up unless i spray carb cleaner down the intake.
after i get it started and run it for a minute or so. I can then turn it off and it will start back up every time without the carb cleaner. untill i let it sit for a while.
also this might be a completely seperate problem. my fuel switch. to turn the gas off, on, and rev. does not seem to work.
the switch can be turned off and the atv will run like its not lacking fuel for a while until i kill it.
thanks
Old Oct 19, 2010 | 02:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have you done a cpmpression test? it should be @ least 100 psi. has the carb been cleaned? does it matter if you pull the choke or not when you try to start it? the valve in the switch might be broke if it's not turning fuel off or on.
Old Oct 19, 2010 | 04:29 PM
kayden101's Avatar
have not done a compression test yet, and no idea how.
carb was just cleaned and rebuilt, it made no difference.
and the choke cable does not seem to matter if its pulled or not.
Old Oct 19, 2010 | 09:10 PM
ftwflh's Avatar
sounds like time for a top end rebuild to me.Check the compression needs to be very least 100psi 120psi better
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 27, 2015 10:04 PM
1000gade
May 27, 2015 12:37 PM
