Adjusting rear brake on 95 Xplorer issue
Old Oct 24, 2010 | 05:19 PM
xplorer400rookie's Avatar
Default Adjusting rear brake on 95 Xplorer issue
Whats the trick to this...If I adjust it tighter so that it actually does something it has constant drag and if I back it off just enough so it doesnt drag, I end up with no brakes in the rear at all!...When I made my adjustment I backed bolt off 1/4 turn at a time.
Old Oct 24, 2010 | 06:16 PM
Overdrive's Avatar
Check the disk. Make sure it slides on the shaft freely. If not you can have this problem.
Old Oct 25, 2010 | 03:29 AM
Try adjusting while holding the pedal down with you hand,turn adjusting bolt in and pedal will rise,stop when pedal is parallel with floor board (about 2" up from floorboard bottom.HOLD pedal down,tighten locknut and then try a couple "panic stops", should be able to stop with no drag if pads and rotor is ok. This is actually a better system than the newer hydraulic system as far as more pressure being applied to rear brakes. Usually you can lockup the rear tires easily! OPT
Old Oct 26, 2010 | 02:11 AM
Thanks I will try that asap
AK47KID
Jul 23, 2015 09:21 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
cornermike
May 27, 2015 10:04 PM
CountryMiles
Oct 25, 2000 01:03 AM
