Should I Change Oil?
Old Oct 25, 2010 | 07:01 PM
Tinbanger's Avatar
Default Should I Change Oil?
Just wanting to get some input or thoughts. Went away this past week-end to go riding, On saturday we went 93 miles. My question is that a little less than half way into the ride, we were going through a pretty deep water hole (for me anyways). While I was in the water hole the water was a little below the seat and my hand slipped off the throttle and before I could get it back on the bike stalled out. After about 2 minutes I got it going and went through the rest of the water and the day with no problems. I was talking to a friend today and he said to change my oil? Should I do this or not. The bike had a fresh oil change and filter 3 rides ago. Thanks in advance!!
Old Oct 25, 2010 | 07:38 PM
Mud Slinger's Avatar
Check your oil for water in it. If you got water in it, your oil will look like chocolate milk. I have ridden through a hell of a lot of water and never had a problem. I check my oil before and after every ride and at every lunch break or extended stop. Only takes a minute and can save a lot of damage. If it has any indication of water, without question, change it.
Old Oct 25, 2010 | 08:01 PM
Tinbanger's Avatar
Would I check it at the dip stick? Or drain a bit? Thanks!! Drove dirtbikes for years and now getting into the fourwheeling I am still in the process of learning everything. Thanks again
Old Oct 25, 2010 | 09:36 PM
Doctorturbo's Avatar
GOT BOOST!
Let it sit for a day or two and crack the drain plug. Just crack it and see if a drop or two of water comes out. The water will phase seperate out and go to the bottom.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
