Changing SP800 Fluids
Old Oct 26, 2010 | 12:52 PM
SwooshManDM's Avatar
Default Changing SP800 Fluids
I need to go through and change the fluids on my 05’ 800. This is my first quad and I don’t know if any of them have ever been changed. I’m fairly mechanically inclined but I’m looking for some guidance on what fluids to actually use. I know I can go to the dealership and spend a fortune on all the specific Polaris fluids but I have no doubt there are equivalent fluids for most everything. I understand that there isn’t a substitute for the Premium Demand Drive Hub Fluid that goes in the front gear housing. All that being said, I’ve found a document floating around that goes over what Polaris recommends and what people use and I wanted to run it by you all and see if there were different thoughts or ideas. I’m not worried about the brake fluid or the coolant, as I know what to use.
Engine oil and Filter- I’m using 10w40 Mobile One Full Synthetic and Polaris filter
Transmission- Read that you can use DEXRON/Synthetic all purpose Transmission fluid
Rear Gear Case- Read that you can use Quality Synthetic 80w-90 gear oil
Front Hubs- Read that you can use Type F Transmission Fluid
Grease- I understand you use any ALL Weather Grease
Is there both a front gear case and a front gear housing? If so, I understand that you can use 80W-90 synthetic gear lube.
I’m open to everyone’s thoughts and ideas. Also, please let me know if I’ve missed anything. Thanks in advance.
Old Oct 26, 2010 | 02:49 PM
JCDEYO25's Avatar
0W40 not 10W40 oil...I use 0W40 Mobil 1 synthetic oil with a Puralator PureONE PL14610 oil filter...Polaris's Demand Drive Fluid in front gearcase for sure for proper engagement...80W-90 Gear Oil in rear dif...
John
Old Oct 26, 2010 | 03:05 PM
Sorry i mistyped the engine oil. I do have 0w40.
Old Oct 26, 2010 | 05:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you MUST use the correct front end oil to avoid major issues w/ the awd. the hillard clutches are very finicky about what type of oil they need to operate correclty.
Old Oct 26, 2010 | 06:04 PM
Kerbbirds's Avatar
you can use the mobile 1 in the tranny too, synthetic 80-90 in the rearend, the polaris demand drive in the front, there are no hubs on your 800
Old Oct 26, 2010 | 06:13 PM
Kerbbirds- By Mobile 1 for the tranny do you mean synthetic motor oil? Same weight as the motor or do you mean another Mobile 1 fluid?
I'm glad to hear there isn't fluid in the hubs, I was getting that impression but wasnt sure.
Old Oct 26, 2010 | 06:21 PM
Overdrive's Avatar
Any good synthetic motor oil will also work fine in your trans. It is actually better than the crap Polaris sells for your trans.
Old Oct 26, 2010 | 06:31 PM
Kerbbirds's Avatar
ditto use the same as your puttin in the engine
Old Oct 26, 2010 | 07:05 PM
How much of each of the fluids? I know the motor takes 2 quarts.
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
