Axle nut, how tight?
I'm gonna try putting a Banshee axle on my Raptor, I've heard it works and is 3" wider. My questions is, about how tight do I tighten the axle nut? I would hate to side load the bearings too much, or do they have a spacer in between the bearings to keep this from happening?
The factory manual has a very specific procedure for tightening the axle nuts. It says to initially tighten the inside nut to a specified torque value, then tighten the outer to a specified value, then re-tighten the inside one to a specified value, and measure the offset between the two. If you don't have the factory manual and a torque wrench (170ft/lb min) that fits the 50mm axle nuts you might want to take it to a dealer. I took mine to one near me and it took the mechanic about 5 min. I slipped him $10. and he was happy. I did not feel comfortable just cranking them down with a pipe wrench like I have heard of some people doing.
is it straight? How many times has it been straightened?? I have a friend who might be interesested..
