Axle nut, how tight?
Old Mar 7, 2001 | 09:19 AM
swayse's Avatar
I'm gonna try putting a Banshee axle on my Raptor, I've heard it works and is 3" wider. My questions is, about how tight do I tighten the axle nut? I would hate to side load the bearings too much, or do they have a spacer in between the bearings to keep this from happening?
Old Mar 7, 2001 | 09:46 AM
redrocker's Avatar
There is a spacer
Old Mar 7, 2001 | 10:16 AM
swayse's Avatar
Cool, thanks redrocker.
Old Mar 7, 2001 | 02:59 PM
maynard's Avatar
The factory manual has a very specific procedure for tightening the axle nuts. It says to initially tighten the inside nut to a specified torque value, then tighten the outer to a specified value, then re-tighten the inside one to a specified value, and measure the offset between the two. If you don't have the factory manual and a torque wrench (170ft/lb min) that fits the 50mm axle nuts you might want to take it to a dealer. I took mine to one near me and it took the mechanic about 5 min. I slipped him $10. and he was happy. I did not feel comfortable just cranking them down with a pipe wrench like I have heard of some people doing.
Old Mar 8, 2001 | 12:30 AM
WarMachine's Avatar
I've had great luck with a pipe wrench. I locked it down, and drove the quad forward to tighten that bad boy. I'm sure I could've found another way, but so far, so good.
Old Mar 8, 2001 | 10:43 AM
swayse's Avatar
Well guys, it doesn't work. It would work if you didn't mind it being 1" wider on one side and 2" wider on the other. I ordered me a Lonestar 2+2. Anybody need a stock Banshee axle for $60?
Old Mar 9, 2001 | 05:22 AM
AdrenalinFreak's Avatar
is it straight? How many times has it been straightened?? I have a friend who might be interesested..
Old Mar 11, 2001 | 09:56 AM
swayse's Avatar
It's strait, I bought this axle used too, it was replaced by a wider axle. It's never been straitened as far as I know, can you tell by looking at it?
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Hack714
Sep 26, 2015 08:11 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
1000gade
Sep 9, 2015 04:41 PM
