polaris transmission oil
Several years ago I bought a 1996 Polaris Magnum 425. My transmission was making a whining noise so I checked and there was not oil in the transmission. I bought some pure direct drive fluid and it seemed to get a little better, but still whines. I just checked the transmission dip stick and there is a small amount of metal shavings on the stick.
The nearest Polaris dealer from me is 50 miles away. I spoke with a polaris dealer and asked if there was a substitute and he said polaris will not give that info to even the dealer. I spoke to a local Kawasaki dealer today and he said Bel ray gear saver transmission oil will work fine in a polaris. Will Bel ray transmission fluid 75 wt work in my Polaris or the Kawasaki dealer wrong? Thanks Guys!
Russ
Russ
The trans on your quad is pretty simple. Gears bearings and a chain for reverse. If you think it is damaged from lack of oil tear it down NOW before other damage is done.
It will not cost much to replace a bearing or two.
Replace the chain also.
I would say rebuild the tranny(new bearings and chain)then use Polaris AGL in it.These trannys are a chain case not gear driven like other trannys and need proper lube.
