94 400 Oil injection
Old Nov 9, 2010 | 01:20 AM
Boxcar34's Avatar
Default 94 400 Oil injection
I have a 1994 Polaris 400 4x4 and I was wondering what the proper way to bleed the oil after the line was removed from the Carb housing? Any and all info would be appreciated I removed the oil line to replace the reed valves, it would die out after letting off on the throttle not sure if that will take care of the dieing out prob but it is the last thing that I could think it is. Thanks in advance again all info is greatly appreciated!!
Old Nov 9, 2010 | 06:03 AM
ftwflh's Avatar
Drain the gas and add about a gal. of 40:1 premix and run it until oil comes out of the injector line.Hook up line fill with gas.The smalll amount of premix wont hurt annything.
Old Nov 10, 2010 | 11:32 AM
Graybeard14's Avatar
My son had some trouble with his 97 400 scrambler, with it trying to stick the piston. Oil system seams ok, but he has gone to using a light pre mix all the time for a little insurance. Smokes a little more when cold, but no problems so far.
Old Nov 12, 2010 | 12:40 PM
Boxcar34's Avatar
I also have a problem when I hit the throttle and back off it just dies however if I just tap the start switch it stays running, has anyone had this problem? It sounds like it might be electrical.
Old Nov 12, 2010 | 05:46 PM
ftwflh's Avatar
adjust the throttle cable.Sounds like your ETC is kicking in.
Cummins Driver
Sep 11, 2019 01:22 PM
dwhipper61
Aug 27, 2015 11:01 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
