Total Rookie Question
Old Nov 10, 2010 | 08:46 AM
Madhammer's Avatar
Default Total Rookie Question
Hello, I'm almost embarrassed to ask this question, but here goes.
I have a 2001 Sportsman 500 H/O. I do not have a model specific manual but instead have a universal Polaris book.
On the right side near the back is a bright yellow, stubby dipstick. Is this the Transmission Fluid Level check?? or is it possible that this is the rear gear case check??
The fluid level is touching the bottom of the dipstick but not int he operating range. Can I simply top it off through the dip stick hole???
Thank you.
Old Nov 10, 2010 | 10:33 AM
scootergptx's Avatar
Supersock
Hired Gun!
That should be it, and you can top it off through the hole.
Old Nov 10, 2010 | 10:40 AM
Madhammer's Avatar
THank you! Should I use the Polaris Premium Synthetic Gearcase Lube mentioned in the manual? Other options. Thanks again.
Old Nov 10, 2010 | 10:48 AM
TLC's Avatar
TLC
I use synthetic snowmobile chain case oil. I heard of others using snythetic 5W-30 or 5w-40 motor oil.
On the 500 and 450 Sportsmans that "unit" does two jobs, its your tranny for High,low,neutral and reverse as well as your rear differential. Most ATVs have a separate rear diff and tranny that does not share the same fluids.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
bigred20653
Sep 19, 2015 02:11 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
