425 magnum carb puzzle
Old Nov 10, 2010 | 05:53 PM
Wademech's Avatar
Default 425 magnum carb puzzle
Carb slide is not opening when the throttle is opened. Eng. starts revving then is choked down. Slide moves freely by hand. Acting like a hole in the diaphram, but there isn't one. Please post any advice on forum.
Old Nov 10, 2010 | 07:37 PM
Overdrive's Avatar
It will not open with the air box off.
Old Nov 10, 2010 | 08:22 PM
4getful2's Avatar
if noone has messed with the spring it's not supposed to open . those type of carbs. need negative pressure(a lil vacuum) to open. you could try putting a finger or two or a lil duct tape across the air intake then peek inside while you're gagging it and it should open. you could try some some carb. cleaner on the slide too,just to make sure it's moving freely. check fuel pump and adjust valves
Old Nov 13, 2010 | 08:18 AM
Kerbbirds's Avatar
Check the lobes on the cam
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
