clutch kit help sportsman
Old Nov 14, 2010 | 03:43 PM
Devoman's Avatar
Default clutch kit help sportsman
06 sportsman 800
I've bought a couple clutch kits and experimented.
Can someone explaine how the springs and weights work so I can figure out what type kit I want.
I like doing wheelies and crawling around in woods. Always seems tached out, is there a way to set up polaris to not rev so much?
Thanks for any info
Old Nov 14, 2010 | 05:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the springs and weights control how fast your clutch will engage the belt. the primary weights and spring will make control how many rpm's will be needed to engage the clutch. if your reving too high your going over your hp band and loosing power. sounds like your topping out your rpm's too quickly from your heavier wights and spring. you may do good wheelies onlow end w/ one set up, but the same set up will loose top end. hope some of it makes sense to you. i used a dalton kit on my 06' and like it. imo
Jmuddin284
Jan 19, 2026 07:16 AM
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
