Need Help with 94 Polaris 400
Old Nov 14, 2010 | 05:54 PM
mekovich's Avatar
Question Need Help with 94 Polaris 400
I have a 94 Polaris Sportsman 400 with 1900 miles. The atv was in excellent condition except the engine let go. It's in the polaris shop now and the cost to repair is $1275.00. My question is would this be too much to spend on an older atv? Should I fix it or scrap it? The dealer doesn't know what to tell me. He said that normally that would be too much but the quad is like new. I may be able to rebuild it myself what do you think? Would this save me some money? Can I buy a rebuilt motor somewhere? This is a 2 stroke. Any advice will be greatly appriciated I am not sure what to do. What would you guys do ? Please help. Thanks
Old Nov 14, 2010 | 06:19 PM
MECHANIKE's Avatar
rebuild it yourself for 1/3 of that price. it will maybe even be fun,,,,,,,,,,2 strokes have no parts hardly to rebuild compared to 4strokes,,,,,,,,,,,,,,,,,,,,,,,
Old Nov 14, 2010 | 06:49 PM
ftwflh's Avatar
I would say rebuild it ............IF..........the cases are good and the counter balance is good.
If either is bad look for one on Ebay.( I have a 94 400 engine but it is called for.If he backs out I will let you know)
Old Nov 15, 2010 | 06:24 PM
Overdrive's Avatar
I know where there may be a like new engine you could buy. IF he still has it.
Call 270-384-6018 during the day and ask for Matt.
Or he may have a good case and other good used parts.
Old Nov 15, 2010 | 06:46 PM
skidoofan's Avatar
I would say rebuild it yourself. Depending on the extent of the damage it could be pretty cheap to rebuild??? But If it were me. I would park it in the weeds. We have two 2000 Magnum 500s sittin out in the weeds with locked up motors. They werent worth fixing. SO we just parked them with the rest of the junk.
Old Nov 15, 2010 | 06:55 PM
H Strine's Avatar
There isn't much on a 2 stroke to rebuild, new seals and gaskets in bottom end, new piston and rings, re-hone or overbore the cylinder depending on the condition, a good cleaning or rebuild of the carb and your set. Why is the motor toast?? Locked up, won't start, no compression???
Old Nov 16, 2010 | 04:44 AM
mekovich's Avatar
Default Reply
Don't know what happened. Got water in fuel last winter and it just stopped. Cleared out water in tank and did a restart no problem then stopped again and couldn't get a restart. when taken apart pistin is broken and rod is bent. Dealer said otherwise quad is like new? It would be a shame to just junk
Old Nov 16, 2010 | 06:29 AM
TLC's Avatar
TLC
If the ATV is in that good of shape, ask yourself ,what kind of ATV can you replace it with for $1275. When it done you will not have a motor with 1900 miles on it any longer as well.
Old Nov 16, 2010 | 05:33 PM
ftwflh's Avatar
Thumbs up
I have to totally agreee on this
Old Nov 16, 2010 | 06:07 PM
94harley's Avatar
I may acquire a 94 400 motor that a cust is probably not going to fix. It has a cracked(not broken yet) piston in it and I don't think he is going to repair it. I will send you a PM and give you my number. I could rebuild the top end with a wiseco and maybe ship it to you if it's reasonable for both of us. I will try to find out wednesday what he wants to do.
