Throttle/Idle issue on my 96 Xplorer
Old Nov 15, 2010 | 01:31 PM
xplorer400rookie's Avatar
Default Throttle/Idle issue on my 96 Xplorer
Sometimes when I back off the throttle all the way and bring down to an idle it will sputter and sometimes even kill, I just completely cleaned carb, so I dont think thats the issue...I can remedy it by turning idle up but then I run into to high of idle to shift without gears grinding...thinking it might have something to do with ETC?
Old Nov 15, 2010 | 01:50 PM
TLC's Avatar
TLC
This maybe you trouble.
Polaris ATV Thumb Throttle Maintenance Tips: Polaris ATV Maintenance & Repair Tips | eHow.com
Old Nov 16, 2010 | 10:08 PM
Checked it out and my cable is completely different...no adjuster that i see!...any other thoughts?
Old Nov 17, 2010 | 04:08 AM
4getful2's Avatar
did you physically take the top off and look inside? on polaris's the cable adjustment is basically the same and the adjuster is on the the cable ,just farther down but still in the handlebar area.
if that's not it then try adjusting the air mix
Old Nov 17, 2010 | 07:03 PM
Kerbbirds's Avatar
Some older ones adjust right out of the throttle box, theres a lock ring on the cable, may need 2 pair of pliers to get it loose.
COFatboy
May 2, 2020 12:06 AM
cornermike
Aug 10, 2016 06:47 AM
cornermike
Jul 30, 2015 06:37 AM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
