Oh yes ,another bearing thread
Old Nov 16, 2010 | 06:15 PM
whalebus's Avatar
Default Oh yes ,another bearing thread
I decided to start a new thread for some of the other problems I am having.Oh yea,I have a 97 sportsman 500.I removed the rear hubs tonight to replace the wheel bearings due to flop.Removed the bearings from the hub,no problem,but I cant find a # on the race or anywhere.I have done a ton of research and cant find any info past 99.they say a ford escort bearing will work on 99 and up but what about a 97.also I removed my belt cover due to wet belt happing and I can see marks like alittle water had been in there but everything else was clean.Any way can I use a jaw puller to remove the clutch or that 40 polaris toll that I can make for $500.thanks guys.sorry for the long post
Old Nov 16, 2010 | 06:38 PM
TLC's Avatar
TLC
Heres how the clutches come off YouTube - Polaris Sportsman EPI Clutch Kit Install - Part 1 of 4
The Rear bearing is BEARING-WHEEL,40X74X40MM
Part #3514635 $21.37 OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
Old Nov 16, 2010 | 06:40 PM
whalebus's Avatar
you are the MAN!! those are great prices>thats what i was looking for.I wanted to try to take it to a bearing house and match it up but at that price ,forget about it.Un fortunatly my local dealer is a idiot so Im trying not to due bus. with them
Old Nov 16, 2010 | 06:44 PM
TLC's Avatar
TLC
The rear bearing on the 97 is used on these ATVs as well if you find a automotive bearing that will work.
I imagine that bearing is used on many more models and years.
2011 RGR RANGER 6X6 800 EFI SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE - R11HR76AG/AR
2010 MIL MVRS 700 4X4 SUSPENSION, REAR - M10YH68MA
2010 RGR RANGER 6X6 800 EFI SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE - R10HR76AG/AR
2010 RGR RANGER 4X4 800 EFI ALL OPTIONS SUSPENSION, REAR - R10TH76/TY76 ALL OPTIONS
2010 RGR RANGER RZR 800 EFI WHEELS, REAR - R10VH76 ALL OPTIONS/VY76AZ
2010 RGR RANGER RZR "S" 800 EFI INTL WHEELS, REAR - R10VH76FX
2010 RGR RANGER RZR 4 800 EFI WHEELS, REAR - R10XH76AA
2009 ATV SPORTSMAN TOURING 500 EFI QUAD WHEELS, REAR - A09DN50EA
2009 MIL RANGER 2X4 500 CARB ISRAEL SUSPENSION, REAR - M09RB50MA
2009 MIL MILITARY RANGER RZR "S" WHEELS, REAR - M09VH76MD/MX
2009 RGR RANGER 6X6 700 EFI CHASSIS, SWING ARM - R09RF68AF/AR/AZ
2009 RGR RANGER 6X6 700 EFI SUSPENSION, A-ARMS, MID DRIVE - R09RF68AF/AR/AZ
2009 RGR RANGER 4X4 500 EFI SUSPENSION, REAR - R09HH50AG/AR
2009 RGR RANGER 4X4 700 EFI ALL OPTIONS SUSPENSION, REAR - R09HH68/HY68 ALL OPTIONS
2009 RGR RANGER 2X4 500 CARB SUSPENSION, REAR - R09RB50AF
2009 RGR RANGER 4X4 700 EFI CREW SUSPENSION, REAR - R09WH68AC/AG/AH/AL/AR/AZ
2009 RGR RANGER RZR 800 EFI ALL OPTIONS WHEELS, REAR - R09VH76 ALL OPTIONS
2009 RGR RANGER RZR "S" 800 EFI WHEELS, REAR - R09VH76AX
2009 RGR RANGER RZR "S" 800 EFI INTL WHEELS, REAR - R09VH76FX
2008 ATV SPORTSMAN TOURING 500 EFI WHEELS, REAR - A08DN50AF/AS/AW/AZ
2008 ATV SPORTSMAN TOURING 500 EFI QUAD WHEELS, REAR - A08DN50EA
2008 ATV SPORTSMAN TOURING 800 EFI INTL WHEELS, REAR - A08DN76FC
2008 ATV SPORTSMAN 500 EFI SCANDINAVIAN WHEELS, REAR - A08MH50SS/SQ
2008 ATV SPORTSMAN 800 EFI SCANDINAVIAN WHEELS, REAR - A08MH76SS/SF
2008 ATV SPORTSMAN 500 HO EFI WHEELS, REAR - A08MN50AF/AN/AQ/AR/AS/AT/AW/AX
2008 ATV SPORTSMAN 800 HO EFI WHEELS, REAR - A08MN76AF/AL/AQ/AR/AS/AT/AX
2008 ATV SPORTSMAN X2 500 EFI WHEELS, REAR - A08TN50AT/AX/AZ
2008 ATV SPORTSMAN X2 500 EFI QUAD WHEELS, REAR - A08TN50EA
2008 ATV SPORTSMAN X2 700 EFI WHEELS, REAR - A08TN68AX/AZ
2008 ATV SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC - A08MH50AX/AZ
2008 MIL MVRS 700/800 6X6 SUPPLEMENT SUSPENSION, MID and REAR - M08YR68MA/76MA
2008 MIL RANGER 2X4 500 CARB ISRAEL SUSPENSION, REAR - M08RB50AA
2008 MIL MVRS 700 4X4/IDF UPFIT/IDF WINCH UPFIT SUSPENSION, REAR - M08RH68AA/YH68MI/MW
2008 MIL MVRS 800 4X4 SUSPENSION, REAR - M08RH76MA
2008 MIL SPORTSMAN 800 HO EFI MILITARY WHEELS, REAR - M08MH76MA/MB
2008 RGR RANGER 6X6 700 EFI CHASSIS, SWING ARM - R08RF68AD/AF/AZ
2008 RGR RANGER 6X6 700 EFI SUSPENSION, A-ARMS, MID DRIVE - R08RF68AD/AF/AZ
2008 RGR RANGER 500 2X4 SUSPENSION, REAR - R08RB50AA
2008 RGR RANGER 4X4 500 EFI SUSPENSION, REAR - R08RH50AF/AR/AT
Old Nov 16, 2010 | 07:08 PM
whalebus's Avatar
just ordered them up>Now if I can get this clutch off and check the rear seals to stop this wet belt issue I will be in bus.
Old Nov 17, 2010 | 07:09 PM
Kerbbirds's Avatar
probably the seal arount the clutch cover causing the leak
rear bearings should be Federal Mogal #510013 can get at parts house
ultangler
Nov 30, 2024 01:35 AM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
jbrewster94
Sep 23, 2015 04:16 PM
