Warrior starting issues
Old Nov 20, 2010 | 12:44 PM
andyhig's Avatar
Default Warrior starting issues
I have a Warrior I've been playing with over the past few months. The quad will not start. I have spark, fuel, and great compression. When I turn the quad over ever now and then I will get a backfire through the carb. Just let's a puff out back into the air box. I've checked timing a bunch of times and it seems to be right on. Woodruff key is also intact and not damaged in any way. Had the carb apart multiple times and cleaned it all up. Any idea what the problem could be?
Old Nov 21, 2010 | 10:18 PM
nickjmck's Avatar
you probably need to check the clutch because the starter engages with it which is called reduction clutch. Try that out, im not an expert on the warrior but i am on the raptors. Try that out, i'll probably have to ask my neighbour. He owns a warrior too.
______________________________________
2005 yamaha raptor 80
2005 yamaha raptor 660r
2008 yamaha raptor 250se (soon)
Old Nov 23, 2010 | 08:33 PM
andyhig's Avatar
I'll give that a try. Might not be disengaging I'm guessing? If thats not it I think I might have a stuck valve.
Old Nov 23, 2010 | 10:01 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Ino you prolly have put new spark plug in already?
Old Nov 23, 2010 | 10:16 PM
nickjmck's Avatar
ok sorry i haven't replyed in a in a long time, my neigbour wasn't here for a couple of days.Anyway check the stator,coil an the cdi box tsee if that will work.
2008 yamaha raptor250se(soon)
Old Nov 26, 2010 | 12:17 AM
Warrior449's Avatar
dose it still have the parking brake
Old Nov 26, 2010 | 04:32 AM
draarong2004's Avatar
even if that was acting up, it would still start, mine did when mine was acting up, i went over everything on my whole quad before realizing it was the parking brake. i'm almost wondering if the wiring hooked up to the starter is correct? maybe its trying to crank it backwards? sounds silly but you never know. but it could also be the coil, stator, or cdi box
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
