Question for EPI Chad
Old Nov 21, 2010 | 08:18 AM
Kerbbirds's Avatar
Default Question for EPI Chad
Will the new style clutches , like from 09 and up XP's work on the older machines? Is the belt lenghth ect the same ?
Old Nov 21, 2010 | 11:31 AM
randyneff6971's Avatar
I`m no pro here but I think if there is going to be a problem with fit-ment it will be on the end of the crank. If the newer style clutch is an upgrade to your machine and the crank sizes are the same I wouldn`t worry to much about the belt because there are 100`s of sizes and my guess is the stock belt will work.
If someone else would chime in that knows to conferm.
Old Nov 21, 2010 | 02:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just do a part number search on the polaris site to cross refence what the clutches will fit. i'm guessing if any thing the belts will be differnt.
Old Nov 21, 2010 | 05:23 PM
Kerbbirds's Avatar
no help with part #s, the xp clutches are actually cheaper to buy new than the 800 clutches, belts are different
Old Nov 22, 2010 | 06:54 AM
kcaves's Avatar
the width is the same though, as long as there is clearance between the belt and the sheaves, should work.
Old Nov 22, 2010 | 08:27 AM
EPIChad's Avatar
I know the secondary clutch will only work on the 550 and 850 machines because they run the reverse direction of a normal clutch and the helix is cut the opposite direction. The primary clutch might be possible but i havent tried it. It does use the new style pull that you use on the rzr. I think you best bet is to get the right one for your machine.
Old Nov 22, 2010 | 08:29 AM
EPIChad's Avatar
and just a FYI, the 2011 550 and 850 XP have a totally new secondary clutch on them that will only work on the 550/850.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
