2007 360 Prairie won't start
Old Nov 21, 2010 | 12:11 PM
timhelms69@yahoo.com's Avatar
Default 2007 360 Prairie won't start
okay,this atv sits probably more than anything you've ever seen,I've had it 2 years now I think and its got maybe 5 hrs worth of use,never any hard abuse,just a yard atv,my freind threaten to come and take it through the mud,(I hate mud),anyway,yesterday I decided I'd uncover it,crank it and maybe ride a little around the yard on it,it cranked fine,ran for about 60 seconds and then cut off,its got good gas in it,the fuel is on,already took the plug out and its got great fire,its not getting any gas,I can spray a little starting fluid in the air cleaner and it'll start but then cut right back off,my ? is,is there some electronic control that tells the carb to shoot the gas,I've looked in the tank,its still new inside,no dirt,trash,nadda, took the gas line off at the carb and fuel flows freely,tapped on the carb bowl severl times,still nothing
give me some ideas here
Old Nov 22, 2010 | 07:26 AM
Jaster94's Avatar
Default common problems
i'm glad you checked out all that you did. those are good things to check out when an atv won't start. NOW, what you need to do is pull the carburetor off of the atv and clean it. don't be scared: this is ok. it's really rather simple and can save you some money. PLUS, if you ever have a problem out riding, you know how to do this because a dealer/mechanic ain't gonna be in your back pocket. block the fuel, disconnect all hoses remembering where they go or mark them with masking tape with a paint pen, OR take a pic with your cell phone. take the carb off, disassemble the carb. pull the jets. the jets will look similiar to this one.
see the orifices? those have to be CLEAN. CLEAN. CLEAN. use carb cleaner, small gauge wire. personally, i use an oxy/acetylene torch tip cleaner pack to clean mine with carb cleaner. use compressed air. make sure you see daylight through every orifice on both jets. that's critical.
reassemble the carb, attach hoses, start it up. if the throttle bogs or it still won't get gasoline, reclean it. it doesn't take much to plug up the holes as you will see when you have it torn apart. please make sure you put the slide back in the way it came out(that's the part on top of the carb that connects to your throttle cable).
have any other problems? post'em. we'll help.
Old Nov 22, 2010 | 02:42 PM
I'll get on it in the next day or 2,thanks
now,how do I change my username,the autofill button did it and I need to change it
Old Nov 25, 2010 | 08:02 AM
Kerbbirds's Avatar
After you get the carb clean and machine running, keep Seafoam in the gas,it will keep the gas good and help keep carb clean There is probably a piece of dirt in the needle and seat, sticking it so gas cant enter carb.
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
kwackermann
Jun 24, 2015 10:18 AM
1000gade
May 27, 2015 12:37 PM
bodatiouskid
May 27, 2015 08:33 AM
