WANTED: AWD Hub Coil old/non working
Looking for used/old/non working AWD Hub Coil to fit a 2001 Polaris Sportsman 500. Rats chewed my wires and I need the mate lock connector off the end. If someone has one, please pm me with price.
Thanks in advance!
Mike
Thanks in advance!
Mike
Just get some wire similar to whats there. put some heat shrike tube on and solder the new wire in place, put shrink tube over splice heat and done. I`ve done this mind you rats didn`t eat my wires it was a stick that broke them. works like a charm and took about 30 minutes.
Lots on Ebay for a good price, the hub coils for a 2001 500 is used on many others Polaris models and years , so do not just seach for 2001 500 Sportsman hub coil.
here is a good write up on working on them. ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Thanks for the info...Trust me, if I had enough wire to solder additional wire to the terminal, I would...There just isn't enough there and I am told you can't solder new wire to these crimp type terminals. I tried to open and reuse the crimp type terminals but that isn't happening...Their too weak.
I ordered some mate lock connectors and terminals from Mouser...We'll see what happens. Hopefully, they are close to, if not stock.
All these ATV use the same hub 5211148 PLATE, ARMATURE set up. Might help when looking.
2009 ATV SCRAMBLER 500 4X4 WHEEL, FRONT - A09BG50AA
2009 ATV SCRAMBLER 500 4X4 INTL WHEEL, FRONT - A09BG50FA
2008 ATV SCRAMBLER 500 4X4 WHEEL, FRONT - A08BG50AA
2008 ATV SCRAMBLER 500 4X4 INTL WHEEL, FRONT - A08BG50FA
2008 ATV SPORTSMAN 6X6 WHEELS, FRONT - A08CL50AA
2007 ATV SCRAMBLER 500 4X4 WHEEL, FRONT - A07BG50AA/FA
2007 ATV SPORTSMAN 6X6 WHEEL, FRONT - A07CL50AA
2007 MIL SPORTSMAN 6X6 MV WHEEL, FRONT - A07CL50MA
2006 ATV SCRAMBLER 500 4X4 WHEEL, FRONT - A06BG50AA/FA
2006 ATV SPORTSMAN 6X6 WHEEL, FRONT - A06CL50AA
2005 ATV SCRAMBLER 500 4X4 FRONT WHEEL - A05BG50AA/FA
2005 ATV SPORTSMAN 6X6 FRONT WHEEL - A05CL50AA
2005 MIL SPORTSMAN 6X6 MV WHEELS, FRONT - A05CL50MA
2004 ATV A04BG50AA SCRAMBLER 500 4X4 FRONT WHEEL - A04BG50AA/FA
2004 ATV A04CH42AA SPORTSMAN 400 FRONT WHEEL - A04CH42AA/AE/AG
2004 ATV A04CH50AA SPORTSMAN 500 FRONT WHEEL - A04CH50AA/AC/AE/AG
2004 ATV SPORTSMAN 6X6 FRONT WHEEL - A04CL50AA
2003 ATV SCRAMBLER 500 4X4 FRONT WHEEL - A03BG50AA
2003 ATV SPORTSMAN 400 FRONT WHEEL - A03CH42AA/AB/AC
2003 ATV SPORTSMAN 500 HO FRONT WHEEL - A03CH50AA/AB/AC/AD/AE/AH/AJ
2003 ATV SPORTSMAN 6X6 FRONT WHEEL - A03CL50AA
2002 ATV SCRAMBLER 400 4X4 FRONT WHEEL - A02BG38CA
2002 ATV SCRAMBLER 500 4X4 FRONT WHEEL - A02BG50AA/AC
2002 ATV SCRAMBLER 500 4X4 FREEDOM FRONT WHEEL - A02BG50AA/AC
2002 ATV MAGNUM 325 4X4 FRONT WHEEL - A02CD32AA/AB/AC
2002 ATV MAGNUM 325 4X4 FREEDOM FRONT WHEEL - A02CD32AA/AB/AC
2002 ATV XPLORER 400 FRONT WHEEL - A02CG38CA
2002 ATV SPORTSMAN 400 FRONT WHEEL - A02CH42AA
2002 ATV SPORTSMAN 500 ALL OPTIONS FRONT WHEEL - A02CH50 ALL OPTIONS
2002 ATV XPEDITION 325 FRONT WHEEL - A02CK32AA
2002 ATV XPEDITION 425 FRONT WHEEL - A02CK42AA/AB
2002 ATV SPORTSMAN 6X6 FRONT WHEEL - A02CL50AA/DA
2002 ATV INT'L BIG BOSS 6X6 FRONT WHEEL - A02CL50AA/DA
2002 ATV XPLORER 4X4 WHEEL (FRONT) - A02CG25CA
2002 PPS LUH 6X6 PPS FRONT WHEEL - C02CL50AB
2001 ATV XPLORER FRONT WHEEL - A01AG25CA
2001 ATV SCRAMBLER 500 4X4 FRONT WHEEL - A01BG50AA
2001 ATV MAGNUM 325 4X4 FRONT WHEEL - A01CD32AA
2001 ATV MAGNUM 325 4X4 MOSE FRONT WHEEL - A01CD32AA
2001 ATV 325 MAGNUM 4X4 HDS FRONT WHEEL - A01CD32AA
2001 ATV MAGNUM 500 FRONT WHEEL - A01CD50AA
2001 ATV 500 MAGNUM 500 HDS FRONT WHEEL - A01CD50AA
2001 ATV XPLORER 400 FRONT WHEEL - A01CG38CA
2001 ATV SPORTSMAN 400 FRONT WHEEL - A01CH42AA
ranvette
Jul 4, 2015 06:13 PM
