550 pound quad winch?
Old Nov 27, 2010 | 08:00 PM
wesleycampbell's Avatar
Default 550 pound quad winch?
ok so i have 2 winches.... a champion 1500 pound winch and a black and decker 1000 pound winch, i own a 1998 polaris scrambler 400 4x4. so the 1500 pound winch is sorta broken. the nuts on the connectors were seized and i broke one off trying to get it off so i opened up the end cap and saw that the wires are all broken and such so id have to re solder the whole thing... so im wondering if the black and decker 1000 will work or i should fix the 1500 or if neither of them are strong enough
Old Nov 27, 2010 | 09:09 PM
Specta's Avatar
I had a Champion winch, it worked twice.
Use a tree saver and a ****** block, double the power of the 1000 pound and have more pull than the 1500 lb with no ****** block.
Old Nov 27, 2010 | 09:42 PM
sorry very unfamiliar with winches and such... so whats a tree saver and ****** block?
Old Nov 27, 2010 | 10:53 PM
biz4two's Avatar
Thumbs up
Hope this youtube video offers some help...
Old Nov 28, 2010 | 06:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you may better off buying a newer heavier duty winch instead of fixing that one. you can find them pretty cheap on ebay or other spots. the only bad thing about using a snach block is that you use double the cable and you might be too far away from a pulling point so maybe an extra strap or chain will help in that case. just a thought.
Old Nov 28, 2010 | 09:52 AM
Specta's Avatar
ATV Television Home Page
This website has winch advertisements for 50% off.
Old Nov 28, 2010 | 10:55 AM
blownc6vette's Avatar
Old Nov 28, 2010 | 11:01 AM
TLC's Avatar
TLC
Polaris makes a ATV as light as 550lbs ?
Old Nov 28, 2010 | 11:33 AM
Specta's Avatar
Too funny TLC.
Old Nov 28, 2010 | 05:03 PM
Kerbbirds's Avatar
I have a 97 425 that probably weighs 600 pounds, have a 1500 pound super winch that was purchased about the same time, it has "done the job" but its not enough, get at least a 2500 lb winch
