06 x2 500 charging problem please help
Old Dec 1, 2010 | 11:31 AM
fireman659's Avatar
Default 06 x2 500 charging problem please help
I am having a charging problem with my 06 x2 500. I Have replaced both the battery and the voltage regulator (that is in front of the radiator). My next guess is the stator. What is happening is the X2 is not charging the battery. when running only about 1-2 volts are going to the battery and the battery is fully charged. Are there any tests to confirm this? What are my next steps. When I charge the battery externally the atv runs fine until the battery gets low.
Old Dec 1, 2010 | 05:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
do you mean you changed out the ecm? the recifier is built in to this. does everything esle work ok? maybe stator has been subjected to water and is causing it?
Old Dec 1, 2010 | 09:45 PM
UTU's Avatar
UTU
Lightbulb no charge
first guess would be the stator IF you have checked ALL the connections?????
Old Dec 2, 2010 | 06:07 AM
kcaves's Avatar
what is ur voltage goin to the rectifier from the stator, check all 3 of the yellow wires. will be ac voltage, all readings should be fairly close
Old Dec 2, 2010 | 12:13 PM
fireman659's Avatar
i would guess that the STATOR has been wet the x2 tried to be a boat in january. any way to fix it or just replace it. Also which side of the atv is it located? Is it located behind the belt and clutch?
Old Dec 4, 2010 | 10:07 AM
Kerbbirds's Avatar
no its on the right sidebehind recoil start
Old Dec 4, 2010 | 11:39 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Do a VAC test on the wires coming from your stator. As mentioned before the voltage should be close to the same on each of the three legs. There should be no less than 30-40 vac between each of the legs above 2000 rpm. If any leg varies significantly you may have a bad stator. Had similar issue last year due to water damage.
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
hondarider1234
Jul 21, 2015 11:53 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
