2007 Bayou Starter turns; but engine doesn't
Old Dec 6, 2010 | 03:19 PM
BabyBear316's Avatar
Default 2007 Bayou Starter turns; but engine doesn't
I bought this non-running Bayou in hopes of fixing it. The starter turns ok; but it will not turn the engine over. I am thinking there is a cog wheel inside the generator case that must be broken/loose. I drained the oil as it probably needed a oil change. I removed the recoil starter and the 6 bolts that hold the generator case. My question is: Does the inside recoil pulley (the one with center bolt) have to be removed. Superman must have put this pully on as I cannot budge it. Does anyone know if this is a backward threaded bolt. Any help is appreciated.
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
merryman
Jun 15, 2015 02:36 AM
clsharky
Jun 8, 2015 11:38 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
