07 Sportsman 500 bogging and dying.
Old Dec 10, 2010 | 03:49 PM
John T. Gilbert's Avatar
Default 07 Sportsman 500 bogging and dying.
My 07 Sportsman 500 X2 has been boogging and dying. Replaced the plug and added fresh gas but it continued bog and this time it backfired a little.
Does anyone know what I should be looking for?
Old Dec 10, 2010 | 05:40 PM
switzomatic's Avatar
Take a look at the air filter. Hopefully it's something simple like that.
Old Dec 10, 2010 | 05:46 PM
Kerbbirds's Avatar
efi, carbureted? if efi sounds like the harness to ur T - Bap sensor has a broken wire. If carbureted, check and see if the boot between the motor and carb is cracked causing an air leak. just spray some starting fluid on it and if the motor revs up, that is ur problem.
Old Dec 10, 2010 | 06:32 PM
JCDEYO25's Avatar
Is it throwing a code 41?...readymixer169 is having a similar situation with his 500...might be an air sensor issue...
John
Old Dec 11, 2010 | 12:49 AM
GTSnoRacer's Avatar
I had a similar problem with my 07 500 efi, waiting for a new sensor now...
Old Dec 11, 2010 | 07:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what modle is it efi or carb as it will help point in the right direction. welcome to the forum.
Old Dec 11, 2010 | 06:38 PM
Thanks for all the info. I cleaned my injector and that took care of the problem. Just had it up to 50mph with no issues!
Old Dec 12, 2010 | 08:01 AM
Kerbbirds's Avatar
Start adding some Seafoam to your gas once in a while, it will keep injectors and everything else clean
mtdewmn
Jan 19, 2017 12:13 PM
Jazperman
Aug 7, 2016 08:12 PM
scram5050
Aug 19, 2015 02:19 AM
cody500ho
14
Aug 14, 2015 05:03 PM
house1
Aug 9, 2015 10:49 PM
