Modified trailblazer with 34mm carb help!
Old Dec 16, 2010 | 11:07 AM
tbsleeper's Avatar
Default Modified trailblazer with 34mm carb help!
Anyone running a modified trailblazer with a 34mm scrambler carb out there? been running mine for a while but recently did a rebuild and replaced the 2 seals on the crank because I had some melting on the top of the piston. Now I cant get the thing to run correctly anymore. It will either just bog or bog then start runnign good and backfire. Cant figure it out. So I was wondering who else has a 34mm scrambler carb on their 250? What is your jetting setup? Im going between 180-200 and all needle positions and cant get it straightened out. help!
Old Dec 16, 2010 | 04:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did it run fine b4 you put the seals in? did you make sure that there isn't still an air leak somewhere? just a thought.
Old Dec 17, 2010 | 04:27 PM
MECHANIKE's Avatar
good question Sten.also where are you? i'm running a #230 main at 800 ft above sea level.i had idle problems cleaned out the pilot hole replaced it runs smooth as silk.
Old Dec 21, 2010 | 12:28 PM
tbsleeper's Avatar
ya Ive always had a ping and idle issues but it always ran. I went up to a 190 cleaned the carb now it runs but still pings and bogs every so often. Im gonna go up to a 200 see if it smoothens out. If it does Ill grab a 210 as well and see how it goes. I think maybe Ive always been running to lean..... The temp outside is from 20-40 now with the winter and elevation is about sea level.
Old Dec 21, 2010 | 01:28 PM
MECHANIKE's Avatar
check your plug so you don't melt your piston.
Old Dec 21, 2010 | 06:32 PM
tbsleeper's Avatar
believe me I do after every ride. Its greyish and real dry, Im thinking Ill just keep upjetting. Probably hunt down a 210 and 220 jet tommorow. I put the 200 in and needle in the lowest position and it still bogs and pings a little. It only starts to bog when it warms up and Ive been on the gas. Im also gonna spray ether (sp?) around all the boots and seals to make sure im not getting a air leak.
Old Dec 21, 2010 | 07:10 PM
MECHANIKE's Avatar
is your needle in the lowest setting or your clip.do you have high compression?did it run good with standard carb?
Old Dec 21, 2010 | 10:12 PM
tbsleeper's Avatar
i have the needle set at full rich so the lowest groove. my compression should be perfect it was just rebuilt because I melted the top of the piston and only had 30lbs compression. I cannot remember hte last time i ran it with the standard carb. Maybe 5 years ago.
Old Dec 22, 2010 | 06:18 AM
sammydogs64's Avatar
When you originally put your 34mm carb on was there a performance increase and what are you other mods?
Old Dec 22, 2010 | 06:51 AM
MECHANIKE's Avatar
i was wondering if you got your head shaved for higher compression/pinging.
