99 scrambler top end 2 stroke
Old Dec 19, 2010 | 07:05 PM
Nick Danger's Avatar
Default 99 scrambler top end 2 stroke
Thinking about buying a complete top end. It has been bored out to .010 and includes the jug, head, Wiseco piston , rings, pin. No gaskets or needle bearing for $185. I get to keep my old head and jug. Sounds like a pretty good deal to me.
A couple of questions:
I take it that I should NOT used any sealant on this?
On the clylinder base, it reads that the bolts should be torqued to 25-29 Ft Lbs. The problem is that a torque wrench won't fit. How do you do you secure those according to the specs?
Anything special I would have to do to the carb, or could I just bolt it all together and be good to go?
Thanks in advance for any advice
Nick
Old Dec 19, 2010 | 08:39 PM
kcaves's Avatar
they make a torque adaptor, designed like the box end of the wrench, goes on a torque wrench, make sure u put it on sideways not straight up cuz that will mess up ur torque. only way to tell if ur carb is gonna need adjusted is to put it all together and see how it runs
Old Dec 19, 2010 | 09:24 PM
randyneff6971's Avatar
They say not to use any sealant but I always do on both sides of the gaskets. clean both surfaces spotless and I put a very thin layer of sealant just to be sure both surfaces seal I then let everything set up before start-up. I hate after a rebuild the oil seepage so i try to keep it to a minimum.
Old Dec 20, 2010 | 07:08 AM
Cave man-
Is there a specific name for that torque adaptor and where can I purchase it? Appreciate your time and efforts.
Nick
Old Dec 20, 2010 | 07:10 AM
Neff man-
What type of sealant do you use? Should I use it on all the gaskets; exhaust, intake, head and base? Appreciate your time on this
Nick
Old Dec 20, 2010 | 07:34 AM
4getful2's Avatar
rtv black
Old Dec 20, 2010 | 09:13 AM
Kerbbirds's Avatar
google torque adaptors and it'll show u what they look like and u could prolly go to harbor freight and get em, no use buyin good ones if ur not gonna use em all the time
Old Dec 20, 2010 | 06:08 PM
Like 4getful2 said, any RTV silicone or gasket maker will work, Keep in mind I also use the proper gaskets I just run and small amount of sealant on both sides before the parts go together just to make sure they seal tight.I do this for everything that needs and air tight seal. I don`t use anything other than the specked gaskets on the exhaust side of the motor, these gaskets are specially made for the heat the motor will put out.
Old Dec 20, 2010 | 07:03 PM
Bird man, Cave Man, Neff man
Got a good tip about using an obstruction wrench. It appears that when you use the
10 mm obstruction wrench (flat with no angle) with a torque wrench, the values become mostly negligable. By using a nut bolt combination on the torque wrench side the values should under as opposed to over. I figure to torque it to the middle range, which should be about right
NeffMan- Thanks for sealant tip. What gasket manufacture do you recommend? I'm going on faith when I order the gaskets that they will be specific for my task.
Old Dec 20, 2010 | 08:41 PM
I have no preference. because I add the little extra it takes to seal. now if I was to use the gaskets by them self I`m sure there are some manufactures that seal better than the others. when I order gaskets what I try to do is find a set that is mid range in price that being said for the most part I`m sure not to get the Chinese brand that says "meets of exceeds factory spec`s". from Hong Kong,
