2000 lt80 stalls on turn
Old Dec 29, 2010 | 04:09 PM
hydaftl's Avatar
Default 2000 lt80 stalls on turn
i have a 2000 lt80 that will stall when i turn right fast only. i can turn and do doughnuts all day if i turn left. carb has been cleaned, tank has been cleaned and new pet **** has been installed but nothing makes a difference. i have even checked for a loose or shorting wire but i have found nothing.
Old Dec 29, 2010 | 06:32 PM
kave's Avatar
Check the throttle cable as well. I'd be looking to see if the cable housing is seated in the barrel nut on top of carb. I guess it's possible you could create slack when turning right. Generally, I would think more tension would be created when turning right. Just a thought.
Old Dec 31, 2010 | 08:47 AM
LT80's Avatar
LT80 Expert
It's a design fault. The fuel sloshes over and covers the carb vent hole.
I drill a extra vent hole in the carb. I can do this for you if you feel the need to fix it.
Old Jan 2, 2011 | 03:11 PM
90 pilot's Avatar
Also, make sure when you put the carb back together that the rubber boot that goes over the main and pilot jet is installed correctly...it should seat around the indentation in the bottom of the fuel bowl. inpropper installation can squish the boot closing off fuel supply through the main jet causing the bike to bog down around mid to full throttle.
Old Jan 3, 2011 | 07:46 AM
LT80's Avatar
LT80 Expert
You can leave that rubber thing out.
TheHood
Aug 8, 2015 05:49 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
Wnthunting
Jul 9, 2015 03:02 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
