Brute Force 650
Old Jan 3, 2011 | 08:37 PM
rwenick's Avatar
Default Brute Force 650
Help! I have a 2005 BF 650 that starts and idles great it even rev's smoothly when you gas it. The problem is it act's like it is just reving up to slow (About 50% as quick as it should be) It does not miss or backfire it just acts like it in in a mode for children to ride it. Since this problem started I have
Adjusted the Valve.
Gone through the carbs.
Reset the belt switch (numerous times).
Can anybody help me?
Old Mar 16, 2011 | 04:26 PM
Hayashi's Avatar
Originally Posted by rwenick
I have a 2005 BF 650 that starts and idles reat it even rev's smoothly when you gas it. The problem is it act's like it is just reving up to slow (About 50% as quick as it should be)
Do a leak down test, or at least compression check to see how tight the engine is. Always do the basic mechanical checks first for engine related issue before guessing anything.
Old Mar 16, 2011 | 06:22 PM
rwenick's Avatar
Default Brute force
Thanks but I got it fixed... the previous shop had the carbs off and pinched both of the carb slider diaphrams under the covers so they were both leaking and the slides would not raise.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
