CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
bombardier quest 650 running problem
Old Jan 6, 2011 | 12:08 PM
scania's Avatar
Default bombardier quest 650 running problem
i have a quest 650 on a 2002 which has a running problem . what the bike does is it will run fine for a couple of minutes when i first ride it then it will back fire and only let u push the throttle just above tick over then if i ride it like this for about five mins to get it hot and switch it off then start it back up it will run fine for about two or three hours then back fire and go to the splutter again i have checked the earths on it cleaned the carb and filter in the carb changed the coil stick just woundered if anyone had any ideas or the same fault and what to check next. Im in the uk and there isnt many people that have worked on this bike.
Old Jan 30, 2011 | 03:03 PM
jaysin52's Avatar
I feel your pain... I just bought an 02 about a year ago and it's my first atv... I've had several issues with it and here's what I've done with mine and it's worked so far:
1. Check the boot between your carb and the head... Mine was dry rotted and cracked 3/4 of the way around. Take your carb and move it up and down with your hand... If there are cracks, you will see them and that's your problem...
2. Check your vents on the top entrance end.. The one on the left should have a vacuum cap and the one on the right should be connected to a hose... I still to this day do not know what these ports do exactly but I do know through experimentation that if you cap both off, it will run super rich, load up, run hot, and not be rideable until you get it cleared...
I hope this helps
Old Jan 31, 2011 | 11:44 AM
scania's Avatar
hi thanks for replying to my problem since i put it on here i have fixed mt atv and the oil light on the dash was broke and then when i got it fixed it turned out that i had a broken oil pressure switch many thanks for your help thow
Old Oct 29, 2024 | 12:46 AM
nickmo's Avatar
I hope this helps
by chance could you upload a picture or explain where that hose on the right side goes to I can’t find it anywhere. Thank you
Gkelso
Feb 7, 2017 10:26 PM
b.kosty
May 23, 2015 05:42 PM
sweatdog
Jan 22, 2011 12:13 PM
naed
Nov 20, 2001 05:25 PM
Crashfirepm53
Jan 10, 2001 09:28 PM
