Any Help Would Be Great Electrical Problem
Old Jan 6, 2011 | 09:35 PM
sudsy's Avatar
Angry Any Help Would Be Great Electrical Problem
04 700 efi sportsman late addition with no spark here is what I got and very confused.
My Manual I have is showing a late o4 but the fly wheel coil and cdi is totally diffent on mine.
I have good ground with good ohms.
ETC Switch good
Kill Switch Good
Stator Ohms Out
Now on the stator cover there is a magnetic ball (I cant find a part listing at all and have no idea what its called) but when I test it doesn't seam to close at all. I followed the wires unplug them took reading with it not against metal nothing put it against metal nothing not sure if I'm doing it write.
CDI unit when cranking is only putting out 10 dcv Manual calls for 20 dcv
Coil cant seam to get ohms on primary or secondary side at all.
SO I know of all the problems with older units but this one is to have all updates. Is it possible the CDI and Coil is bad at same time? Hate to just start buying parts. I like to know about that magnetic ball. Thanks sorry for the winded message
Old Jan 8, 2011 | 07:47 AM
Kerbbirds's Avatar
probably needs ignition kit#02202602 some of these bikes had problems, be ready there not cheap
Old Jan 8, 2011 | 06:47 PM
4getful2's Avatar
I think it's odd that you cannot get any readings off of your coil.If the connections are a booger to get at, you may be better off physically removing it and the wires to it ,for troubleshooting.
Old Jan 10, 2011 | 11:29 AM
sudsy's Avatar
Thanks
02/03 and early 04 had a lot of problems from what I have been reading. My ignition has totaly diffrent stator,coli and cdi unit. I ordered the crank coil going to start there then move on have no other options.
ripperray
Oct 10, 2023 02:42 AM
Mkp
Mar 28, 2020 03:50 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
WilliamBos
Jun 11, 2015 05:57 PM
garyt1975
Jun 5, 2015 08:53 AM
