In need of help!!
Old Jan 13, 2011 | 09:34 PM
Chieft's Avatar
Default In need of help!!
Hi,
I am new to the site. I recently picked up what i believe is a polaris trail boss. there is no plastics on it nor can i find a sticker telling me exactly what it is. Anyway....I used the front end and the swingarm with the gear box to build my son a mini sand rail. I can not get it to go in the forward gear. There is a solenoid on the gearbox by the selector lever, if this is not working will it keep the gearbox from going in the forward gear? Neutral and reverse work fine. Thanks for any help
Old Jan 14, 2011 | 10:01 AM
Welcome to the forum. If you haven't already, ask your question in the Polaris section to get a better answer.
Old Jan 15, 2011 | 12:09 PM
Chieft's Avatar
heou
I thought i was in the polaris section..?? Anyway, I believe i have uncovered more information about the switch/solenoid that i am talking about on the gearbox gets it's power from the brake. when the brake is pressed it tells the gearbox that it is safe to put it in the forward gear. Now what i am trying to find out is will it go in forward if i take the switch out of the gearbox? Or another thought is hook it up to a toggle switch to activate it when you want to go in the forward gear.
Old Jan 15, 2011 | 01:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you are in the polaris section. moose must of thought he was reading this in a differnt section. i don't recall any solenoid on the transmission. the switch on the tranny as you mentioned is to indercate what gear it is in or some years did have the push brake to shift out of park gear. either way i do not beleave this would effect shifting into foward. is there a linkage youy can adjust? if not maybe some how the shifting fork inside of the tranny got bent??
Old Jan 16, 2011 | 03:05 PM
Yep, Moose's brain was certainly elsewhere. Sorry 'bout that.
Old Jan 16, 2011 | 05:40 PM
Kerbbirds's Avatar
should be 2 rods from shifter to gear box, thats not a selenoid, its a box with oil in it and a wire out of it that wasa gear shift position switch , if rods are adjusted correctly it wont have any effect on shifting, put tranny in nuetral manually and adjust all rod ends so they line up perfectly centered, I would guess shifter is mounted a little off
Old Jan 20, 2011 | 05:54 AM
Chieft's Avatar
Been a few days since i have had a chance to get on here. I finally got the gearbox repaired. It was actually the shiftfork causing all the problems. But, thats nothing that the ole tig and vertical mill could not handle. Thanks for everyones help. As soon as i get a chance i will post some pics of the build.
Old Jan 20, 2011 | 06:59 AM
paraord's Avatar
Told ya Chieft, these guys over here are great and have lots of good info.
