What kind of plastic are the body panels made of?
Old Jan 16, 2011 | 11:09 PM
signal15's Avatar
Default What kind of plastic are the body panels made of?
I have a couple of cracks on a 98 Sportsman. Minor, but I don't want them to spread. I'm going to plastic weld them, but need to know what kind of plastic they are so I can use the correct filler rod.
Most of the panels seem to be polypropylene, and the black trim seems to be ABS. But, I might be wrong. I called polaris, and they didn't know.... and they made the damn thing. They told me to call a dealer, so I did, and the dealer told me to call Polaris.
Does anyone know?
Old Jan 17, 2011 | 07:06 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Polypropylene ! we weld plastic also and we use the rod for that an does an great job.. although the black rod does the best for us,, the green, red, an others don't hold as well....
Old Jan 17, 2011 | 10:56 AM
signal15's Avatar
What about the black trim? This seems more rigid and brittle, I'm thinking that the trim is ABS.
Old Jan 17, 2011 | 06:19 PM
randyneff6971's Avatar
Since we are on the subject. I have a 99 sportsman and it has a good crack on the front plastics. I have been studying plastic welding and think I could do it easily. my question is I have plastics here from another polaris if I was to cut a slice off of the junk 1 will I be able to use it as a filler rod since its the same composite???
Thanks don`t mean or intend to hijack thread.
Old Jan 18, 2011 | 06:56 AM
Loved
Community Favorite
Signal15... We use the same rod for both... had no problems at all.......
Old Jan 18, 2011 | 07:01 AM
Loved
Community Favorite
Randyneff...Is your fender ripped completly off? if so. I don,t see any problem piecing together and weld.... are you wanting to use other fender parts instead of rod??? then i'm not sure it will melt or weld the same as an rod thats design to weld,melt and weld to two pieces.......
Old Jan 18, 2011 | 04:49 PM
No its not riped off yet, on the front right side near where my knee would be there is a crack about 8" long. If i cut a piece off of the spare fender (that is junk) about a 1/8" strip I was thinking it would act like a plastic welding rod since its the same material and has the same melting point, am I wrong in thinking this?
Thanks for the input Randy.
Old Jan 19, 2011 | 12:20 PM
King Quad's Avatar
Urethane Supply Company - Plastic Repair and Plastic Welders
There is good information on this website and I use it all the time.
Old Sep 6, 2019 | 05:38 PM
Brian Llewellyn's Avatar
I have to repair my sportsman body as well as a kayak and looking into plastic welding. Many instructions recommend cutting a strip from an unseen portion of the same panel to be used as filler material. Your use of a junk piece should be fine, by their way of instruction.
nachop
Feb 14, 2018 06:57 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
chris7420
Jul 30, 2015 02:04 PM
1966F100
Jul 24, 2015 02:17 PM
toonces
Jul 11, 2015 12:01 PM
