electrical problem need help
Old Jan 17, 2011 | 07:50 PM
phkn's Avatar
Default electrical problem need help
can anyone tell me how to test the stator to make sure it is good. also is the sscb a breaker and if so where is it located on a 2006 sportsman 500
Old Jan 18, 2011 | 09:38 AM
sudsy's Avatar
You should have three wires comming from the case of the stator. Follow them they should plug into your voltregulator. you will need a wire schematic to look at the color coded pins and it should give you a ohms reading. Note if you doing this because of no spark keep in mind your crank positioning coil is also located on the stator case you should unplug it and ohm it as well. Hope this helps
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
