How exatcly does a clutch weight kit improve acceleration?
Old Mar 9, 2001 | 11:44 AM
dosperado's Avatar
I am curious as to what the heavier/lighter clutch weights do to the belt drive system in an automatic quad such as the Grizzly that improves performance? And are there downsides as well? Any info would be great, thanks.
Old Mar 9, 2001 | 04:01 PM
thenewfiebullet's Avatar
You should check on some of the snowmobile forums to really get a goos idea of how these clutchs work.
Basically, heavier clutch weights will grab the belt harder, and will not allow the motor to rev as high or as quickly. Lighter clutch weights will do the opposite.
With a fairly low output, fourstroke motor, I wouldn't play around with the clutch weights, but instead concentrate on the driven clutch. You can change how the quad will upshift, and backshift by changing the helix and driven spring.
shimanok2
Jan 29, 2016 07:37 PM
jbrewster94
Sep 23, 2015 04:16 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
