compression test
Old Jan 31, 2011 | 01:36 PM
trees's Avatar
Default compression test
i know how to do a compression test and i've read about the oil seals in a 2 stroke not sealing and causing running problems, but i have a question about compression readings. on a 2 stroke if you do a compression test. will the gauge still register the correct value if you have bad seals. my thinking is that it would and the seals would only show up if you did a bleed down test. i was getting around 100 psi and my trail boss 250 wouldn't idle and was very hard to start. i ordered a new top end rebuild kit with a 20 over piston and will put it in as soon as it arrives. i also ordered seal but would like to know what to expect.
Old Jan 31, 2011 | 01:39 PM
94harley's Avatar
Your seals(good or bad) will not affect the reading from a compression test.
Old Jan 31, 2011 | 01:42 PM
trees's Avatar
94harley thank you. i didn't think so but i am so new to 2 strokes. i just want to do this right.
Old Jan 31, 2011 | 05:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just need to do a compression test w/ a cold engine and the throttle wide open for best results. as mentioned it wouldnt effect it. also that is about the min. compression you would want to run with. imo
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
