Kvf 360
Old Jan 31, 2011 | 01:50 PM
oskosh's Avatar
Default Kvf 360
Hi I have a problem with a KVF 360, it wont go into reverse, I move the shift lever into r but nothing happens, HELP.
Thanks oskosh.
Old Feb 2, 2011 | 01:00 AM
oskosh's Avatar
So nobody out there has any Ideas then?????.
Old Mar 16, 2011 | 03:37 PM
Hayashi's Avatar
Is this a permanent problem or intermittent?
If it is intermittent, it can be a linkage issue.
If it is permanent, the reverse gear could be broken. You need to split the case to check/verify.
