Carb swap questions
Hello again guys. I'm having problems with the carb on my 1995 300 4x4. I tried cleaning it out, then tried rebuilding it. The machine is still running like crap. It's running pig rich, blowing a ton of smoke and it won't rev up high. I think the carb might just be worn out. I made sure all of the new jets were the same # and all of the other parts matched. I'm at the point where I just want to put a new carb in it and be done with it. I'm considering a 30 tmx, or a 30 koso. I'm trying to keep the swap as inexpensive and easy as possible. The oil pump is already blocked off, so that should make it a bit easier. Any suggestions? As always, your help is appreciated.
The machine has a fairly fresh top end. The top end was just broken in when I bought it. I was skeptical about it, until the guy showed my receipts for, and pictures of the rebuild. Just to be safe, I did check the compression. It has 125 psi. I did not check the crank seals though. I think I might get some new ones and put them in. Even if they are not bad, at least I can rule them out. Can I leave the motor in the machine to replace crank seals?
Ok, I started tearing the quad apart already. I had to quit early because it's FREEZING outside, and I don't have any heat in my garage. I took the pull start assembly off to expose the flywheel, and removed the clutch cover and front clutch. Does anyone know what size bolts are needed to thread into the flywheel to remove it?
Over the years they used both sizes. The 8mm is more popular it seems. Try one of the recoil bolts, if they thread in, it's the 6. If it just pushes in, its the 8mm. Saying that tho, those bolts are not long enough. The ones I use are 6mm x 1.0 x 55, 8mm x 1.25 x 60.
Awesome. Thanks a lot 94Harley. You have been very helpful. I'm going to take your advise on checking the piston also. Do you think I can get a good look at the piston skirts through the intake with a mirror?
I checked the piston out today, and it doesn't appear to be broken. I'm just waiting on my buddy to bring his 3 jaw puller over. I can't believe i haven't bought one of those yet, lol. I hear that the flywheels on these bikes can be very very stubborn. Is it ok to use an impact gun on the 3 jaw puller when removing the flywheel?
