Carb swap questions
Old Feb 15, 2011 | 11:26 AM
SlowAndHighTBI's Avatar
I don't know what the magnets on the back of the flywheel are secured with. I don't want to risk shaking them loose with the impact. I'm going to try to pop it off by hand. If that doesn't work, then I'll try the impact.
Old Feb 15, 2011 | 04:13 PM
94harley's Avatar
I have never used a 3 jaw puller to remove a flywheel. I wouldn't recommend it but without the specisl puller it;s a little hard to not try to come up with another method. I use an impact gun when I remove them, but with the special puller too. I have seen guys have trouble breaking magnets, but in my experience it was because they were trying to remove the flywheel by hitting the puller bolt with a hammer causing shockwaves I assume. Let us know how it goes.
Old Feb 20, 2011 | 11:44 AM
I ended up using a run of the mill 3 jaw puller on it. My flywheel had the 3 8mm openings. I checked the bolts I threaded in to them periodically to make sure they weren't stretching. I did end up using my snap on impact. It made short work of the job. I just made sure the puller had fresh lube on it. To my surprise it popped right off. The magnets were fine, and I didn't even have to persuade it with a hammer. I did experience a bit of difficulty however. WHY THE F***** WOULD POLARIS USE PHILLIPS HEAD FASTENERS TO SECURE THE MAGNETO TO THE CASE!!!!! They were so tight, I had to use vise grips to get them out. Now I'm just waiting on parts. My dealer wants 35 bucks for both seals....What a rip-off! I'm trying to find a cheaper source for those.
Old Feb 20, 2011 | 01:05 PM
Kerbbirds's Avatar
Need an impact screwe driver for those phillips heads
Old Feb 21, 2011 | 04:21 PM
  #15
Yeah. An impact screwdriver would have come in handy. I'm leaning towards grade 8 torx head to put back in when I'm all done. Does anyone know where I can find crank seals for a good price?
Old Mar 26, 2011 | 06:27 AM
  #16
Ok, sorry about the long hiatus. We just got done moving....boy was that fun. Anyways, I put the new seals in. One of the seals I got was different (black rubber over the whole thing, I'm pretty sure this was the stator side) but it still fit good. I put most of the bike back together just to try running it. There is a huge improvement. The bike will rev nice, smokes way less, but now it wont idle. I had rebuilt the carb before hand with all new parts, and the gas wasn't connected to it while it sat. I'm going to try a different spark plug and see what happens. Does any one have any other ideas?
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
