xp550 proplem
Old Feb 14, 2011 | 12:04 PM
wlvrn's Avatar
Default xp550 proplem
i have an 09 550xp and it just started acting like its cold blooded when starting. it has not had this problem before and the past 3 0r 4 times i have gone to start it, the starter is turning and some times it turns over. after about 5-10 mins of trying it starts but wont idle till it warms up good. i am thinking maybe a spark plug or coil but im not sure. any thoughts?
Old Feb 14, 2011 | 02:10 PM
Mongrol's Avatar
"Official Site Skeptic"
Probably spark plug or ECM needs resetting.
Old Feb 14, 2011 | 02:49 PM
BlackRaptor's Avatar
No check engine lights?
Old Feb 14, 2011 | 02:53 PM
wlvrn's Avatar
the wrench comes up for about 20 secs but then goes off. its done that since i bought new tho. how do i reset the EMC?
Old Feb 14, 2011 | 05:17 PM
Mongrol's Avatar
Thats a dealer job.
Old Feb 14, 2011 | 05:43 PM
Kerbbirds's Avatar
try changing the plug , they have been fouling plugs if you dont get it good and warm every time you start it, see if you can replace the champion with an ngk plug, not sure of the number for the 550
Old Feb 14, 2011 | 05:47 PM
Mongrol's Avatar
Good point KERBIRDS. They have to idle about 5 min to warm up and get the ECM off the warm up circuit. If not, it stays rich and will foul the plug.
Old Feb 14, 2011 | 06:02 PM
IQSLEDNECK's Avatar
As crazy as it sounds, check your battery. My friend had a problem with his running rough when it was cold, he took it to the dealer and they narrowed it down a battery and it now runs like a top! I was suprised that the battery was giving those kind of issues but it was
Old Feb 15, 2011 | 01:46 PM
wlvrn's Avatar
Mine came with an ngk plug number I think is brk6e. I have put a new one in still the same. If it was the bat wudnt it die after crankin for a long period of time? Bat checks out good I think but it can't hurt to test it
Old Feb 15, 2011 | 08:02 PM
hallj86's Avatar
You really took it home with the ecu up?
