new owner with questions
Old Feb 22, 2011 | 01:57 PM
unclejtl's Avatar
Default new owner with questions
Hello everyone,
I just purchased a 97 400 4x4 cheap, but knowing it needed an engine. apparently the small bearing on the counterbalance shaft let go. i have torn it down and here are my questions... ( yes,a manual is on order )
1. anyone press apart the counterbalance and replace that bearing before? any tricks?
2. anyone press apart the crank to replace the rod? any tricks? or can the small rod end be bushed? the piston end of the rod is grooved from a stuck bearing.
I will be needing the two case halves as there is a few small holes. the cyl and head look good. nothing has been done to the engine before, so 1st oversized will work.
on to the rest..
3. it has a fox shock on the rear, is it rebuildable? where do you get your parts?
4. does anyone know what the wattage the stator puts out? for bigger lights.
5. what year quads are the same as mine? in looking for parts.
thanks for your input.
jason
Old Feb 22, 2011 | 08:57 PM
kcaves's Avatar
i actually have a motor out of a 98 (i believe its a 98) 400, bottom end is good in it, top end needs redone that i would be willing to part ways with. send me a pm if interested
Old Feb 23, 2011 | 08:01 PM
unclejtl's Avatar
kcaves, i sent a PM to you, did you get it? never done it before...
Old Feb 23, 2011 | 08:04 PM
kcaves's Avatar
yes i got it, sorry work gets in the way, i'll get some pics and figure out a price when i get off work, i'll pm u friday
Old Feb 23, 2011 | 10:02 PM
unclejtl's Avatar
great, thanks! yes i know work gets in the way of all the fun things!
Cole Hadden
Jun 15, 2025 09:05 AM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
cdstang
Aug 31, 2015 07:52 AM
Dan Newberry
Aug 30, 2015 09:42 AM
