2007 Honda Rincon
Old Feb 27, 2011 | 08:51 PM
mcginty_greg@yahoo.com's Avatar
Default 2007 Honda Rincon
I am trying to remove the axles from my 2007 Honda Rincon rear end? Anyone have any ideas????
Old Mar 2, 2011 | 11:46 AM
unit6666's Avatar
they just yank out.. give them a good hard tug and pop!!
Old Mar 7, 2011 | 07:46 PM
ATV Connection Reporter's Avatar
From the ATV Connection editors:
The process should begin with you removing the axle nuts. Because of the leverage required here, we find it works best to do this with everything still on the machine. Once you get the nuts loosened, go ahead and take off the wheels, hubs and rear brake.
Of course due to space restrictions, we do hope you realize that in addition to wheels, hubs, axle nuts, washers, spacers and o-rings that will have to come out in the process but once you’ve got them removed, you should be able to pull the axle out towards the brake side.
We have found it easier to use a long 1/2" rod as a punch with which to lightly tap the axle out from the differential. If the axle still refuses to budge, using a pry bar may yield similar results but in either situation, use extreme caution not to damage the differential’s housing.
Though not cheap, you may want to consider investing in an axle slide hammer for the actual task of pulling free the axle (which has proven invaluable to the staff of ATV Connection in these situations).
Thank you for asking your question!
Sjrpp
May 2, 2023 03:59 PM
Nondem
Feb 22, 2020 12:20 PM
Sjrpp
Jun 2, 2019 07:25 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
ylomnstr
Sep 4, 2015 05:02 PM
