muddy radiator
Old Mar 3, 2011 | 09:56 AM
jdnovak418's Avatar
Default muddy radiator
Anyone got tips or tricks on gettin dried mud off a radiator without removing it or bending the cooling vents??? I don't want to relocate because if it won't be as protected .... forman rubicon 500
Old Mar 3, 2011 | 10:30 AM
convicted21's Avatar
I'm curious about this myself...
Old Mar 3, 2011 | 10:43 AM
BEC300ex's Avatar
i just spray water at it until i can see light through it i have never bent anything and has always worked for me.
Old Mar 3, 2011 | 11:32 AM
jdnovak418's Avatar
Well I should have mentioned clay as well its like concrete and water just won't cut it. I have removed it once to clean it but its to much work for all that..
Old Mar 3, 2011 | 12:56 PM
TLC's Avatar
TLC
Maybe hot water, try hooking your hose to your kitchen tap. Maybe a hot water supply to a power washer but I,m not sure if hot water would wreck the power washer.
Old Mar 3, 2011 | 03:20 PM
SeniorCitizen's Avatar
Try this -
Get it cleaned up good and make sure it is totally dry
Run motor until radiator is warm/hot
Spray top and bottom of fins with Pam or another non stick
cooking pan product.
Let radiator cool overnight
Not sure if this will work with clay - none where I live -
but it works with cow S$$T - and PLEASE - don't any of
you guys ask how I know !!!
Good luck, Senior
Old Mar 4, 2011 | 05:01 PM
jdnovak418's Avatar
a pressure washer alone will mess it up ..itll bend the cooling vents.. yeah i ride in a cow farm from time to time cow $h1t does suck.. thanks guys for the info
Old Mar 6, 2011 | 05:44 AM
JeffinTD's Avatar
RV shops will have a product called a Tank Saver. It is intended to reach into the drain plug of an RV water heater and spray the scale out of it.
Basically it is a plastic tube/wand with a bend at the end, that attaches to a garden hose.
You can usually get to the back side of ATV radiators with one.
Pgbama11
Jan 16, 2016 08:19 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Pgbama11
Sep 10, 2015 08:20 AM
